Novaturn won't connect
dixonsca
Hardware/Software: Denford Magnum router. (now upgraded to a 3d router using retrofit kit macmotion controller and upgraded stepper motors)
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
Makerbot Replicator 2
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Post by dixonsca » Fri 12 Jul , 2019 9:17 am
Hi All. I am having an issue trying to connect to an upgraded to USB nova turn using VR turning. It seems it is still trying to connect using the RS232 and searching com ports rather than looking at the USB port. I am told it has worked previously so am I just missing a setting somewhere? Thanks for any help.
usb connect1.jpg (24.35 KiB) Viewed 8731 times
Re: Novaturn won't connect
Post by Martin » Fri 12 Jul , 2019 12:01 pm
It could be any one of the below.
1. Have you installed the USB drivers?
The 32 bit & 64 bit USB drivers should be on the cd but you can download them from,
http://website.denford.ltd.uk/software- ... s-support/
2. Make sure you have the correct machine selected.
viewtopic.php?f=42&t=5723&p=23050&hilit ... NNS#p23070
3. Check that the seven segment LED on the control card is lit. May be a blown fuse.
dixonsca
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Post by dixonsca » Fri 12 Jul , 2019 12:27 pm
Thanks for quick reply.
1 Drivers are installed.
2 I tried both machines from the select machine menu but didn't check they matched in the parameters. Hopefully it will be that. How do you know if its the NovaTurn or NovaTunNS or is it a case of try both and see?
3 will check this also.
Will update once I've had a look but may be a day or two.
Post by Martin » Mon 15 Jul , 2019 9:43 am
If the control card is USB then it's a NS.
dixonsca
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Post by dixonsca » Thu 18 Jul , 2019 8:40 am
Thank you for clarifying its NS.
