Novaturn Dimensioned Drawings
- Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3 - Location: Quatroland
Re: Novaturn Dimensioned Drawings
no probs, it'll take me a while to get it apart.
- Iron-Man
- CNC Apprentice
- Hardware/Software: Modified NovaTurn with Yaskawa AC Servos +-10V, PathPilot running on a GizmoSphere 1 with Ibob2 PCIE interface that I designed. Denford Triac to be modified with AC Servos.
angel-tech wrote:no probs, it'll take me a while to get it apart.
Thanks, angel-tech.
Iron-Man
4 Quatros
3 Oracs
2 Easiturn atc
all apart, ask away.
I have printed the BOM for the TP121 Turret.
I have highlighted the parts we have in stock in Green. We only have one or two of each of the bits which are for spares use.
I would assume you will be able to locate the electrical parts elswhere but may be interested in the Main Shaft worm shaft and worm gear.
I have also priced thes components.
I will see if I can add the drawings for the toolpost body and tool turret.
- turret TP121 parts list.pdf
- (55.98 KiB) Downloaded 926 times
Here is the drawing for the turret assembly, the turret body and the tool plate.
- Tp121.pdf
- (128.32 KiB) Downloaded 970 times
- Tp121_02.pdf
- (171.55 KiB) Downloaded 1066 times
- Tp121_01.pdf
- (185.25 KiB) Downloaded 5968 times
- Iron-Man
- CNC Apprentice
SteveSteve wrote:Here is the drawing for the turret assembly, the turret body and the tool plate.
Thanks for all the information .
Iron-Man
- CNC Apprentice
- Hardware/Software: My Novamill, bought in Nov 11 without electronics, is now up and running under Mach3 with a home-build control box. I'm very pleased with the machine, only project so far is correcting a cheap small machine vice originally bought for a vertical slide to use on the machine - not a right-angle in it when bought!
Iron Man -
Which Harting connector was it in the end please?
I have a Novamill which seems to use the same type but no control box so am going to use Mach 3. I don't want to start rewiring the mill so need to find a connector.
Admin, please could you confirm that the Novamill and Novaturn use the same type?
Thanks,
John.
Thanks,
John.
- Iron-Man
- CNC Apprentice
I have not purchased it. I lost some of my research on an older computer and have not recovered it yet. I believe that it is a Han® 42 DD connector. http://www.harting.co.uk/imperia/md/con ... n_d_dd.pdfJohnHaine wrote:Iron Man -
Thanks,
John.
See page 13 of the above document. Also, see this file viewtopic.php?f=42&t=2629 document NVT-D11E.pdf.
Hope this helps,
Iron-Man
- CNC Apprentice
Great, thanks for your help.
John
John
