Schematic Circuit Diagrams for the Novaturn
Post by Steve » Mon 22 Feb , 2010 15:10 pm
Attached are the schematic Diagrams for the Novaturn
Turn.zip
(617.18 KiB) Downloaded 725 times
MadeForThat
Hardware/Software: 2x Micromill 2000:
Denstep cards with beta chips, running vr milling through a usb-rs232 converter and using all stock electronics otherwise. Looking to change to Nextstep card to allow tapping into 4th axis.
novaturn ns:
Nextstep card but unable to run on modern vr turning due to lack of support for older license files. Likely will be receiving a centroid acorn controller and software.
Re: Schematic Circuit Diagrams for the Novaturn
Post by MadeForThat » Fri 13 Sep , 2019 18:20 pm
I only see half of the denstep card and half of the nextstep terminal blocks, does anyone have the upper side of the denstep and the lowerside of the nextstep? I am looking for specifically how the speed/feed pots are set up
Post by Martin » Mon 16 Sep , 2019 10:03 am
Both bottom cards are the same so use the same connections.
MadeForThat
novaturn ns:
Post by MadeForThat » Mon 16 Sep , 2019 18:34 pm
thanks martin,
Perhaps this is a stupid question, but the "control voltage" on the machine tags just refers to the component voltage outputs, not the operating voltage of the the control card itself, correct?
Post by Martin » Tue 17 Sep , 2019 7:58 am
