Easy Change tool holders
- CNC Apprentice
- Hardware/Software: My Novamill, bought in Nov 11 without electronics, is now up and running under Mach3 with a home-build control box. I'm very pleased with the machine, only project so far is correcting a cheap small machine vice originally bought for a vertical slide to use on the machine - not a right-angle in it when bought!
Does anyone have dimensioned drawings for the spindle fitting end of Easy Change toolholders please?
John.
John.
- CNC Apprentice
Re: Easy Change tool holders
Thanks - as they don't give dimensions they are obviously potentially easy to make!
- Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3 - Location: Quatroland
the critical dimensions are going to be the taper diameter and the rear face of the groove.
- newsletter1107.pdf
- (1.09 MiB) Downloaded 3166 times
- CNC Apprentice
That looks like the one! Well spotted, and thanks. John.
4 Quatros
3 Oracs
2 Easiturn atc
really usefull, thanks
- CNC Apprentice
You can buy these from J&L if you get stuck and if you look out for the discounts you can save a few bob. I think the easy change system is great but takes up a lot of room on an already limited head height machine. hence why I raised the column. There are some nice ISO30 collet holders about though.
