Cutting PLywood
kieranwalsh1
Hardware/Software: CNC Router 6600
Quick CAM 2D/ PRO + VR MILLING.
Cutting PLywood
Post by kieranwalsh1 » Fri 27 Jul , 2012 15:32 pm
Looking to cut some 12 mm Plywood on a Denford 6600. There is no settings for plywood, though standard settings for MDF/Hardwood. Any advice on settings/speed/Depth of cut for Plywood much appreciated.
Re: Cutting PLywood
Post by Denford Admin » Fri 27 Jul , 2012 15:41 pm
Just pick hardwood/mdf.
You can always adjust the Feedrate override (and possibly the Spindle override) if it's going too fast or too slow and burning
Depth of cut probably OK as well.
Use a bit of trial and error and create a new material if you find anything needs altering a lot.
Large519
Hardware/Software: Denford Triac PNC3
FeatureCam - CADCAM
Delcam Powershape
Re: Cutting PLywood
Post by Large519 » Fri 17 May , 2013 13:36 pm
Speeds and feeds dont really come into play with ply, there is very little resistance from it, we cut alot of ply at 6000rpm and 4000 m/min 3mm depth of cut. You best source of a good cut is to use a down cut tool, ie instead of a normal end mill the flutes rotate upward, with a down cutter the flute rotates downwards. It will give less chipping on the edge of the wood.
