Failed "Z" axis stepper motor
All info relating to the Denford MicroRouter Compact small routing machines
CoreyG
Post by CoreyG » Wed 24 Oct , 2012 9:43 am
We have a well used Compact MicroRouter that has cut out hundreds of F1inSchools cars... Recently our "Z" axis motor went dead... Wires broken inside the housing.
I am assuming with age of machine that spares could be a little difficult, considering the web site listed on the side of the motor is no long active.
Is it possible to get some technical data on the motors? That way I could source a new retro fitted motor?
Alternatively you might have some still in stock at Denford... Sweet... How much to get it here to Aust ;-)
Thanks,
Corey
Corey G
Re: Failed "Z" axis stepper motor
Post by Denford Admin » Wed 24 Oct , 2012 11:15 am
It'll cost a bit to get to Aus but you could try source one yourself:
http://www.portercable.com/
Our price is 395GBP + TAX + SHIPPING and we have them in stock.
Alternatively, you could try fitting another motor which may be easier for you to source, and modifying the motor clamp.
You will probably have to remove the speed controller and wire the new motor directly to the mains...it will then only run at full speed unless it has speed control on the motor body itself (some do, some don't)
CoreyG
Post by CoreyG » Wed 24 Oct , 2012 21:48 pm
Thanks Admin team,
That is good to know about the router motor...
I might not have been as clear above, sorry... It is the stepper motor with or without brake that I am keen on sourcing.
Thanks heaps.
Corey
Corey G
Post by Steve » Thu 25 Oct , 2012 9:07 am
Hi, The Z axis motor is fitted with a brake. The one you had was probably made by MAE which we no longer use but we do still use an equivalent.
The item is BI00422BK and will be available in Australia through REA our agent there.
Re-Engineering Australia Foundation Ltd.
Unit 11/3 Packard Ave Castle Hill NSW 2154
(Post) PO Box 136, Castle Hill, NSW 1765
(Ph) 1300 204 478 | (Fax) 02 8079 0622
(Mobile) +61 407 054 483
http://www.rea.org.au
Post by Denford Admin » Thu 25 Oct , 2012 9:17 am
Sorry! I should have read the title properly! Failed "Z" axis stepper motor
