Microrouter Compact - black dust
All info relating to the Denford MicroRouter Compact small routing machines
Benny
Post by Benny » Wed 15 Apr , 2009 17:05 pm
Customer writes in
The router stopped running last week. I noticed a lot of black dust in the cabinet and thought it might be brushes. Please advise
Benny
Post by Benny » Wed 15 Apr , 2009 17:06 pm
You may need to replace the spindle motor brushes.
You can loosen the pinch bolt and remove the motor from the machine. The brushes are held in place by the two round slotted black caps.
The brushes are about 3/4” long each. If it is worn down to about half the size, you will need to replace them --- contact your local Porter-Cable / Dewalt / Black and Decker repair center.
Also check the fuse (F1, 10 amp) for the spindle motor inside the back panel of the machine.
Vacuum out the motor and use compressed air to blow the wood dust out of the motor.
boots
Post by boots » Thu 23 Apr , 2009 20:21 pm
Here is a photo of a new motor brush
