Psu Flashing
gjm72
Psu Flashing
Post by gjm72 » Mon 02 May , 2016 9:29 am
Hi Just wondering if anyone has had this problem, I started my microrouter up the other day and all I got was a flashing fluesant light, so I undid the cabinet and I have a s on the denstep board and the psu is flashing in time with the fluesant light. Has anybody had this before.
Many Thanks
Re: Psu Flashing
Post by Martin » Wed 04 May , 2016 11:51 am
It sounds like your light is faulty & shorting out the 24 volts DC. Some of the earlier machines had a switch on the end of the light which you could turn off to try.
gjm72
Re: Psu Flashing
Post by gjm72 » Thu 05 May , 2016 13:10 pm
Hi martin Thanks for the info but the light seems to be ok, checked the output of the two wires and only seem to be getting 2v every 3seconds so it looks like it could be a short circit or lack of 24v from somewhere.
Graham
gjm72
Re: Psu Flashing
Post by gjm72 » Sat 28 May , 2016 12:47 pm
Has anyone had a psu go down.? I think this is the problem as I have 240v going in and all I get out is 1-2v with the green light flashing surely the green light should stay on with 24v comeing out.
