Microturn Machine Mis-match error
Posted: Fri 14 Oct , 2022 9:05 am
by Mazhar
Hi everyone,
Just installed the latest version of VR cnc turning on windows 10 and I get the message Machine mis-match error and suggesting it is a Microturn 2000 instead of the Microturn 2000NS. everything seems to work fine its just annoying every time I start up I get the error. I did try to switch it to micro turn 2000 and it cannot communicate with the machine.
The badge on the machine suggests it is a Microturn 2000NS and the machine I have is usb.
Re: Microturn Machine Mis-match error
Posted: Fri 14 Oct , 2022 10:31 am
You can change the Machine Type in Denford Easyupgrader.
You can install it from the VRTurning CD or download it from the Denford Website.
You will need to connect to the machine, Then Right click on the banner at the top. Then go in to Advanced (Password is Dave).
We used to set the Microturns to Unknown.
Posted: Fri 14 Oct , 2022 11:15 am
by Mazhar
Hi Martin,
Thankyou for the quick reply. All sorted, Thankyou very much for your help much appreciated
Posted: Wed 26 Jul , 2023 18:52 pm
by Dodds
Martin wrote: ↑Fri 14 Oct , 2022 10:31 am
I have the same issue. Says mis-match! Novaturn should be Novaturn NS
When I do as Martin says, I do not have a Novaturn NS to choose from in the list of machines! Question is, will it be safe to set to unknown/special for my NS
David.
Posted: Fri 28 Jul , 2023 7:34 am
Yes set it to Unknown/Special & it wont display the warning.
Posted: Wed 02 Aug , 2023 22:51 pm
by Dodds
Thank you very much Martin.
