Hi, I just got this used machine. I am new to CNC and will be taking some classes,
What I can tell it’s a micromill 2000 but not sure.
The board is a smartstep 3 with a denment 2.0B
Software VR CNC Milling V 2.28 and Mill Cad Designer V2.22
I don’t have the serial cable and seen different pin out to make one, just want to make sure I get it right for this machine.
I turn the machine on as it sits and it powers up and get I a number 8 on the board.
Also the spindle works when I adjust the variable pot.
If I can get some information on my findings it would be a great help.
serial cable
Re: serial cable
here are the connections mounted on 25 pin d-sub connector on side of cabinet
- DSC05808.JPG (106.02 KiB) Viewed 6616 times
Re: serial cable
This post shows the cable details right from PC to control card:
viewtopic.php?t=544
Whatever goes in-between must end up with the pins at one end being connected to the correct pins at the other...ie plug everything in and check that pin 2 on the pc 9-way goes to pin 3 on the Baldor 9-way etc..
viewtopic.php?t=544
Re: serial cable
Are you in the USA?
If so refer to this post:
viewtopic.php?f=54&t=2351&p=8468&hilit= ... able#p8468
The attached post shows the internal cables.
I believe you have a US MicroMill and a Microturn so the internal cable you have fitted will be: BI01812B
The external cable is a BI01812N This is a standard Null modem cable.
viewtopic.php?f=36&t=2384&p=8630&hilit=BI01812A#p8630
The attached link shows the connections required if you connect a cable directly to the Baldor control card to the PC:
viewtopic.php?t=231
You can buy a cable in the USA from Newark
PRO SIGNAL - PSG90340 - LEAD, MODEM, 9WAY-25WAY D SOCKETS
Newark Part Number: 43T6042 Manufacturer Part No: PSG90340
http://www.newark.com/pro-signal/psg903 ... dp/43T6042
See attached drawing of cable (this would allow connection of 25 way to 9 way or 25 way to 25 Way)
viewtopic.php?t=231
Re: serial cable
Steve,
Thanks for the reply. I tried the null modem cable but the computer could not find the mill.
I made the 9 pin to the controller and the 9 pin to computer.
I tested all axis to home and jogged each axis and all is good. Is this cable just for testing or can I leave it wired this way? I wired it from the post below.
viewtopic.php?t=544
viewtopic.php?t=544
Re: serial cable
It's up to you.Is this cable just for testing or can I leave it wired this way?
Now you know what connections work, you could make a suitable cable to connect to the (25 way?) connector on the outside of the machine.
