Easiturn z axis drive fault
Posted: Sun 12 Apr , 2009 15:15 pm
Hi can anyone help
I have an easiturn 3 with z axis drive fault. I ve had the machine running but went to zero the machine the other day and it came up with this fault. I ve taken the cover off the control and the second red light is on on the z drive board, reading the manual this means there is a power supply problem. I ve checked all the fuses. Any ideas on what to do next would be appreaciated.
Some other questions i have:
Is it ok to run the machine on a normal 13 amp socket?
what is the best software to use when using a rs232 to communicate with the pnc. Cheers Steve
