Managed to find a Denford Cyclone a few months back and a friend picked up the machine and converted it to Mach 3.
Macro for the toolchanger.
Got the machine running today and all works great. The only thing I was puzzled by was when the coolant flows out of the back of the spindle bore it does not seem to have anywhere to go?
I need to machine a few drill holder blocks on the Triac and turn some sleeves and I should be good to go.
Need to setup all of the tools in Mach 3 and try get a part running.
Nice parting tool was in the machine. It always seems to be tricky to part off though. Any ideas on best speeds and feeds for 25mm aluminum?
Cyclone on Mach
Re: Cyclone on Mach
Pictures of the machine
- cyclone_3.jpg (153 KiB) Viewed 4890 times
- cyclone_2.JPG (70.29 KiB) Viewed 4890 times
- cyclone_1.JPG (65.02 KiB) Viewed 4890 times
Re: Cyclone on Mach
It sits well across from 2 Triacs on Mach 3
- triac_1.jpg (79.82 KiB) Viewed 4890 times
- Hardware/Software: Denford VR Milling
Bobcad V28 Mill/Turn CadCam software
Fanuc
Haas
Heidenhain
Inspect3D
Re: Cyclone on Mach
nicely layed out. i like how you have your triac vmc's. what did you use for the control panel assembly were the keyboard and screen goes? looks very nice
