Y axis is no longer referencing
All info relating to the Denford Compact 1000 and Compact 1000 Pro small routing machines
rolf
Hardware/Software: Denford Compact 1000
EO0295
September 2009
VR CNC Milling 5.29
Post by rolf » Thu 20 Apr , 2017 10:52 am
Formula 1 in Schools from Hamburg, we have a problem with our milling machine Denford Compact 1000.
The Y axis is no longer referencing. When trying to do so, it travels slowly away from the limit switch and not towards it.
When overriding home and driving manually, it travels at the normal speed in all directions. When hitting the limit switch, it stops like it should, but when we try to drive to the other end (which hasn’t a mechanical switch), it doesn’t stop but tries to go further.
The little “Y”-sign in the home flag remains green all the time.
After repeated testing, the axis won’t even go to the limit switch now, it now just stops after a few seconds.
Re: Y axis is no longer referencing
Post by Martin » Thu 20 Apr , 2017 12:22 pm
It sounds like you have a faulty home switch.
You may be able to vac the switch out if you place the vacuum next to it & activate the switch manually several times.
https://isupply3d.com/denford-section/d ... mit-switch
rolf
EO0295
September 2009
VR CNC Milling 5.29
Post by rolf » Mon 24 Apr , 2017 10:10 am
Martin wrote:It sounds like you have a faulty home switch.
rolf
EO0295
September 2009
VR CNC Milling 5.29
Post by rolf » Mon 24 Apr , 2017 10:41 am
Thank you!
It was a loose contact!
Rolf
