Maintenance Guide
All info relating to the Denford Compact 1000 and Compact 1000 Pro small routing machines
davidfhu
Maintenance Guide
Post by davidfhu » Wed 06 Oct , 2010 2:25 am
Is there a maintenance guide for Compact 1000? I have being milling for almost a 1000 cars. Only did general vaccum and lubricant.
Anything that we need to take note? Anything that we need to take a part to clean, in order to prolong the machine life?
Best regards,
David Fhu
“Dream as if you'll live forever, live as if you'll die today.” - James Dean
Re: Maintenance Guide
Post by bradders » Wed 06 Oct , 2010 7:34 am
Compact 1000 Operator / Maintenance Manual
Compact 1000 Operator Manual.pdf
(3.68 MiB) Downloaded 13452 times
davidfhu
Post by davidfhu » Wed 06 Oct , 2010 9:33 am
Hi, Bradders.
I have this doc. I am looking for Maintenance Guide as for Authorised Router Motor Service Station. My closest one should be Denford direct, as I am in Singapore.
I am providing support for Singapore customer.
Best regards,
David Fhu
Post by Denford Admin » Fri 08 Oct , 2010 10:59 am
The main thing is to keep it clean and lubricate the slideways and screws.
There is nothing more to do than what is specified in the Operators manual (Page 30)
davidfhu
Post by davidfhu » Mon 11 Oct , 2010 10:49 am
Thank you for your information.
Am I right to say that we can ignore those area that we can't reach and we would not need to unscrew any parts to lubricate it?
This is the kind of question that my local teachers and lab assistants like to ask.
Best regards,
David Fhu
Post by Steve » Mon 11 Oct , 2010 11:43 am
You should not need to strip anything down unless you have a problem.
The only thing that could do with maintanance is the Spindle motor. Removing this from the machine and cleaning it out with a vacuum or airline is a good thing to do.
Also cheching the wear on the brushes is a good idea. It is better to replace these before they cause a problem.
