I have tried using Techsoft 2D Design with the denford extension and then using VR Miller to see the output. The problem is VR Milling shows my drawing being rastered ie being machined in lines rather than being profiled.
The result is a circle that looks like a sprocket !
Can anyone please help me out on this one as I really need to get this working quickly.
Raster problem on Techsoft 2D Design
Why did I choose this profession, cos it aint for the money !
A plain circle or arc in techsoft would normally come out as a profiled arc move in VR Milling through the Denford Extension.
Maybe your 2D Design has got a line thickness, or has some sort of fill, which is causing lots of raster lines to be generated by the Techsoft software.
Attach the .des file for us to look at if you like
Problem solved
Hiya, solved the problem, I didnt assign the correct colour to the vector line and therefore no profile !
Thanks for the offer of help
