QuickCam 3D VR milling v5 on Triac fanuc OM-B
bjornove
Hardware/Software: Model : Triac fanuc
Machine Serial No : E0 3543
Orginal customer : Bachke Maskin
Order No 3415
control supplier : Fanuc
Model : 0M-B
serial no : 8060460
Software version 0415-09
Post by bjornove » Tue 24 Feb , 2015 22:37 pm
Hey
i am having bit of a headache with a old Triac Fanuc- OM-B machine from 1988ish.
i have tried using EdgeCam to send cnc codes, but i seems that the post processor ain't right. it says that i am using a wrong code.
tried sevreal driffrent set ups, but haven't got any further.
so what i am wondering about now is:
1.Will Quickcam 3D work with this machine, just plug it in and be on my way
2. how expensive is quickcam
3. will i need both quick cam and vr milling v5, can i just use one of them and wich is best
4.does VR milling v5 work with triac fanuc OM-B, how much does it cost
Big thanks
Re: QuickCam 3D VR milling v5 on Triac fanuc OM-B
Post by Steve » Wed 18 Mar , 2015 16:05 pm
The VR Milling will not run the machine.
You may be able to get a program out of QuickCAM Pro that would run on the machine but there is a limit to the size of file that can be stored in memory so you will probably have to drip feed the machine.
