I am considering using BobCAD with VR Milling 2.3 and VR Turning
Does any one know which of the many posts that BobCAD/Cam has is best?
Does any one from Denford Support have an idea how I might know, is there a spec I could use.
BobCAD Which Post to use with VR Milling VR Turning
Re: BobCAD Which Post to use with VR Milling VR Turning
This post should help if you need to create your own.
Start with a basic Fanuc 0M or 0T post and try not to use Cycles (ie, have Bobcad expand cycles into G01,G02 and G03's)
- Croy
- Hardware/Software: Standard Modern 1334 Lathe
Bridgeport Mill
Still trying to find time to learn BobCad
Interested in helping others with their Electronics needs. - Location: Cardiff
if you post a request on BobCad site they will respond and answer you.
Sotty, I meant to link to this post:Denford Admin wrote:This post should help if you need to create your own.
viewtopic.php?f=16&t=1370
