I need help in getting a post file that will run on our Light Machines educational mill.
the Larken Camtool post does not work...although the G-code looks vary similar...the light machines will not read how the tooling information is written.
I have attached a sample engraving file of a snowflake from the Light Machines Mill software. Perhaps that can help you figure out a post file for the Light Machines mill.
thanks, -OV-
Light Machines - Post Processor
- flake2006fix.zip
- (5.07 KiB) Downloaded 787 times
Can you try this file out on the proLight please ?
It should be nearer to what you need...
- proLight.zip
- (2.87 KiB) Downloaded 827 times
