Thanks to alastairseggie for this info:
BBC Stuff
I use beeb em http://www.mkw.me.uk/beebem/BeebEm411.exe as it can emulate a master which is what I have.
Use Xferhttp://www.g7jjf.com/progs/xfer51a.zip to transfer from BBC with 5.25 disk to a PC
OR
Use Omnidiskhttp://www.shlock.co.uk/Utils/OmniDisk.zip on a PC with a 5.2
This gets the disk in to the PC then make an immage using Omnidisk or from XFER use BBC Explorerhttp://bbc.nvg.org/util/BBCExplorer-2.01.zip. BBC explorer can also extract files form immages or combine files to make an immage.
Roms can be extracted using readrom or an eprom programmer (which I have).
Attached are the disk immages and the rom but they are untested Once I get everything working i will tru extracting back to 5.25 and see if they work. They do work on the emulator.
Have fun
BBC Starmill Software
- Starmill BBC Software.zip
- (84.51 KiB) Downloaded 753 times
