The No. 202 May 2013 edition of Model Engineer Workshop magazine includes an article on a copier attachment for a Denford Viceroy lathe (but easily adaptible to any other lathe).
If you already have a Denford copy/taper attachment, this is an easy accessory to make and adds useful capability.
If you don’t have the Denford copy/taper attachment, it would be straight forward to reproduce both attachments.
If the lathe looks familiar, it’s probably because you have seen it on this forum.
Model Engineer Workshop : Cross slide copier
- dazz
Dazz
Dazz
- dazz
Re: Model Engineer Workshop : Cross slide copier
Attached are some photos that show a cross slide copier attachment. This is designed to copy the profile of a template onto the end of a bar. This is something that cannot be done with the factory copy attachment. I have used parts of the factory copier to make the cross slide version, but nothing that could not be reproduced in the home work shop.
Dazz
Dazz
- Shows how the bar that holds the template is fastened to the lathe.
- Photo 5 template bar.jpg (348.45 KiB) Viewed 11795 times
- The top slide rotated away to show a template in place.
- Photo 9.jpg (357.08 KiB) Viewed 11795 times
- A template is bolted to a drilled flat bar and the roller follower controls the tool path.
- Photo 10 stylus following the template.jpg (281.43 KiB) Viewed 11795 times
- The pieces that replace the screw and add a roller follower.
- 010.jpg (26.29 KiB) Viewed 11795 times
- An overview of the end profile copy attachment.
- IMG_2432.JPG (387.98 KiB) Viewed 11795 times
Dazz
Dazz
