Specifying circle radius or diameter
el$syd
Post by el$syd » Mon 14 Dec , 2009 18:17 pm
Using QuickCam 2D to cut circle depth 1mm and width 2mm in aluminium, radius outer is 44.33 mm and inner is 42.33 mm - could use a lathe, but felt that the CNC Mill would enable me to repeat the process as I would like to make several parts with this same setup.
Using the drawing tool for circles - it asks me for centre point, no problem. But then asks for the radius or diameter, the only way I can specify this is with the mouse and the radius indicator at the bottom of the screen. This means that the best resolution I can get is one mouse move (rotation of the mouse ball for one increment) in x or y, is there a way of numerically specifying the radius rather than using the mouse?
Also, if I want to keep my overall design but alter the radius of one of the circles using the 'alter select' tool, it will correctly alter the circle - but there is no radius showing at the bottom of the screen. So I have to delete it and start again! Which makes the alter tool for circles not very useful :(
I am probably missing something somewhere and help would be much appreciated.
Re: Specifying circle radius or diameter
Post by Steve » Tue 15 Dec , 2009 9:35 am
Lots of ways to do this.
1 Move the curser to the center of the circle and click. Then when you are asked to set the radius move your mouse to the top of the screen and click the dimension tool to incremental and type 43.33 into the X box and then click OK.
2 Draw the circle the aprox size you want then select it, right click and select properties. Set the radius to 43.33 and OK.
3 Once you have drawn one circle just copy and paste.
:D :D :D :D
el$syd
Post by el$syd » Tue 15 Dec , 2009 9:43 am
Many thanks - that is very helpful :D
Post by Denford Admin » Tue 15 Dec , 2009 9:46 am
- or just double click on the circle to get to properties
