Stereo lithography files
We seem to be having a problem transforming a folder from PDT to a stereo lith file and the error reads, 'Can't create STL file because of invalid geometry' Do you know why this might occur?
Not 100% as I don't use PDT, but I think it will be due to things like:
badly intersected parts
cutouts that don't remove anything,
cutouts that don't leave anything,
eg zero thickness walls
If you are in an assembly, apparently you have to use the option to "use component" in order to bring in each part used in the assembly - hope this makes send to you
